kernel: pid 42320 (audacity), uid 1001: exited on signal 4
Please state:
Elimelech
Post by Elimelech » Tue Sep 18, 2018 7:41 pm
I have: freeBSD 11.2, Lumina 1.4.1
When they start to save the file in mp3 format, the program falls. The
error code in the attached file. what to do?
When open any file with an extension of mp3, then edit it in the
program, then when you save this file in mp 3 format, the program
falls down. :(
After that I click on the "ok" button and the program just closes.
I have a 32 bit freeBSD system
The program audacy put out of packages:
pkg install audacity
/home/luba #
Code: Select all
pkg info audacity
audacity-2.2.2_3
Version        : 2.2.2_3
Installed on   : Thu Aug  2 23:15:22 2018 EEST
Origin         : audio/audacity
Architecture   : FreeBSD:11:i386
Prefix         : /usr/local
Categories     : audio
Audacity_dbgrpt-89470-20180917T141246.zip
(8.75 KiB) Downloaded 12 times
Re: kernel: pid 42320 (audacity), uid 1001: exited on signal 4
Post by steve » Wed Sep 19, 2018 1:04 pm
If the problem only occurs when exporting as MP3 (and other formats are OK), then the problem could be due to LAME.
Does LAME work from the command line?
Elimelech
Post by Elimelech » Wed Sep 19, 2018 4:00 pm
Code: Select all
[email protected]:/home/luba # lame -h -b 48 Nigun_Hamagid.wav audio_01.mp3
Illegal instruction
Code: Select all
$ audacity
ALSA lib seq_hw.c:466:(snd_seq_hw_open) open /dev/snd/seq failed: No
such file or directory
13:59:14: Debug: ScreenToClient cannot work when toplevel window is not shown
13:59:16: Debug: Unrecognized accel key 'backspace', accel string ignored.
13:59:16: Debug: Unrecognized accel key 'numpad_enter', accel string ignored.
13:59:16: Debug: ClientToScreen cannot work when toplevel window is not shown
Illegal instruction
