saving an edited tune.
coonsanders
Post by coonsanders » Mon May 25, 2009 8:45 pm
hi
after you edit a tunewith audicity how do you save it?do you use "save project as" or "save project"?"save project as"allows you to name the song but you can also do the same with "save project".....does audicity stort these "audicity files"in its own
area or can you config it so they will go into your regular "my documents"area?thanks.
lenny
allencmcbride
Re: saving an edited tune.
Post by allencmcbride » Tue May 26, 2009 6:16 am
The only difference between "save project" and "save project as" is that the latter will allow you to rename an already-saved project. But if you're done editing, you probably shouldn't use either. Instead, export the project to WAV or something like that. That way you can rename or move the file as you please. Audacity "projects" are not single files, but collections of files. While you can put them wherever you want on your computer, moving or renaming them can be tricky for new users. --Allen
coonsanders
Post by coonsanders » Tue May 26, 2009 12:09 pm
hi
thanks 4 your input....
coonsanders
