thanks guys
suttlemyre
thanks guys
Post by suttlemyre » Thu Sep 13, 2018 7:25 pm
Have played around with this program 2.2, does everything I need. wish I could send a check but i'm living in my brothers garage for a bit, thanks lil sample
sample mp3 audacity 2.2.mp3
(242 KiB) Downloaded 36 times
Trebor
Re: thanks guys
Post by Trebor » Fri Sep 14, 2018 6:39 pm
sample mp3 audacity 2.2.mp3 (242 KiB)
A good performance , but the recording is mono.
If you used stereo you could put the overdubbed vocals wide so it sounds like different people singing together,
(because they would then sound like they're in different places in the stereo-field).
I can only approximate the effect because I only have your mono mix to work with ...
prayer2spare, before-after.mp3
headphones recommended
(1.03 MiB) Downloaded 24 times
There are many free psuedo-stereo / stereo-widener plugins
this is a good one ... https://www.youtube.com/watch?v=P819NzjN4rw
suttlemyre
Re: thanks guys
Post by suttlemyre » Sat Sep 15, 2018 3:59 pm
Thanks for the tips and hints, hurricane getting close, NC, gonna have a few good days to pick and record. yall have a good one.
