Audacity 2.1.3 records at half speed...
rayday
Post by rayday » Tue Sep 11, 2018 12:27 am
Hi! using Win 8.1 on a non-internet-connected PC, Audacity (fresh install) 2.1.3. Things worked perfectly several months ago when I last used the computer; now I start up again and: when I record, the timeline advances very slowly, i.e., at the 10-sec mark on my watch, Audacity is at the 5.0 mark. Naturally, playback is garbled, as playback is at normal speed. Had this problem once before and I thought that several computer reboots solved the problem. Now that doesn't work (if it ever did) - can't find anything in the manual or here re this, although I may have missed it. Any help?
Thanks, Ray
Re: Audacity 2.1.3 records at half speed...
Post by steve » Mon Sep 24, 2018 9:35 am
The current version of Audacity is 2.2.2 and the next version (2.3.0) is due to be released very soon.
The latest version is always available via the Audacity website: https://www.audacityteam.org/download/
Try updating Audacity and see if the problem still happens.
