Crackling with Bluetooth headphones
Help for Audacity on macOS.
popopop830214
Post by popopop830214 » Sat Sep 08, 2018 4:58 pm
When I press play while using bluetooth headphones (with any kind of audio), the audio stutters a bit and there are a bunch of crackling sounds. After leaving the audio playing for a couple seconds, both the stuttering and the crackling stop. This happens only when I use bluetooth headphones, and never with wired headphones/built-in speakers.
(I'm running macOS High Sierra, version 10.13.6, and Audacity 2.2.2).
Re: Crackling with Bluetooth headphones
Post by kozikowski » Sat Sep 08, 2018 11:24 pm
Do you have any other BlueTooth devices connected at the same time?
What does the manufacturer have to say about it? Is there a FAQ where it turns out lots of people have this problem?
popopop830214
Post by popopop830214 » Tue Sep 11, 2018 10:18 am
No, I only have the one pair of BlueTooth headphones.<br/>
I've searched everywhere, and I couldn't find anyone else with this problem. And it's not a problem with the headphones, as this only happens with Audacity.
popopop830214
Post by popopop830214 » Fri Sep 14, 2018 3:50 pm
Any ideas?
Doctor__Hammer
Post by Doctor__Hammer » Thu Sep 20, 2018 4:46 am
Hey! I had the same problem and just figured it out. All I did was I changed the audio output from my bluetooth headphones to "MMAudio Device", one of the four options for output besides my headphones, built-in output, and "MMAudio Device (UI Sounds). Hope that works for you too!
