Changing an unknown key,pitch
dnel57
Post by dnel57 » Fri Aug 31, 2018 10:38 pm
Wondering if there is a way to change an unknown key to a certain key, as unknown key to key of D
Thanks
Audacity 2.1.0
Windows 8/64b
Re: Changing an unknown key,pitch
Post by steve » Fri Aug 31, 2018 11:59 pm
You will have to work out what the "unknown key" is. Audacity cannot guess what key you want to transpose from.
