Mix & Render Only Selected Region of Multiple Tracks?
dgpretzel
Operating System: Windows 7
Post by dgpretzel » Fri Aug 31, 2018 7:11 am
Windows 7
Audacity 2.2.0
I have several synced stereo tracks. I would like to select a region in three of those tracks; and then mix & render to a new track only the selected portions of the three tracks. Is there a way to do this?
Thank you.
DG
Re: Mix & Render Only Selected Region of Multiple Tracks?
Post by steve » Fri Aug 31, 2018 8:32 am
Do you want those sections to also be removed from the original tracks so as to leave the unselected portions in the original tracks?
