Is it possible to separate solo and accompaniment?
LeeX
Post by LeeX » Mon Aug 27, 2018 10:42 pm
Hi,
I guess the answer is no but let me double check just in case...
Suppose I have one audio file that has both solo and accompaniment (two tracks combined). Would it be possible to use Audacity or any other tools to separate solo from accompaniment, and save them in two tracks (files)?
Thanks & regards,
Lee
DVDdoug
Forum Crew
Re: Is it possible to separate solo and accompaniment?
Post by DVDdoug » Tue Aug 28, 2018 12:33 am
Generally, no. "You can't un-fry and egg or un-bake a cake, and you can't un-mix audio."
Of course if the solo is on the left and the accompaniment is on the right, you can delete one channel and make a mono file (that plays out of both speakers).
And there are some "center channel" tricks... You can remove the "center channel" vocals (and other centered sounds), that is sounds that are identical in the left & right channels, by subtracting left from right. Or with more complicated processing you can keep the center and kill the separate left & right sounds. (Vocal Reduction and Isolation)
Post by kozikowski » Tue Aug 28, 2018 2:07 pm
Other than that center track trick we can't split a mixed performance into individual voices, instruments or sounds.
Even that center track thing has limits. If the production added stereo echo to the voice, the echo will hang around.
http://kozco.com/tech/audacity/clips/MysteryTrain3.mp3
Also note the bass and drums go away.
LeeX
Post by LeeX » Tue Aug 28, 2018 4:24 pm
Hi,
Thanks so much for the information from both of you. It helps. Really appreciate it!
Regards,
Lee
