Error Opening Existing .aup file
gcraig9211
Error: not well-formed (invalid token) at line 151
Re: Error Opening Existing .aup file
Are you actually using pre-release Audacity 2.3.0? Are you complaining about it creating damaged Projects, or it fails to open an existing Projects? Other?
waxcylinder
gcraig9211
Hello,kozikowski wrote: ↑Sun Aug 26, 2018 10:07 pmAre you actually using pre-release Audacity 2.3.0? Are you complaining about it creating damaged Projects, or it fails to open an existing Projects? Other?
I'm using 2.2.2 and trying to open existing .aup files. Some work, some don't. My computer crashed. Computer repair shop fixed. Now, some .aup files give me this error. Using Windows 10.
waxcylinder
Have you read and tried the page link I sent earlier in this thread?
gcraig9211
I did try that link. Saw the errors. Looks like some file names were missing. Nothing worked. I'll re-record those sessions. Thanks again!
