USB Driver
abagail242
USB Driver
Post by abagail242 » Thu Aug 23, 2018 11:49 pm
I run Windows 10. When inserting my USB cord from my turntable, I get a msg "USB Device Not Recognized" . "Unknown USB Device Descriptor Request Failed". Has anyone else encountered this and do you have a fix?
Re: USB Driver
Post by steve » Fri Aug 24, 2018 12:51 am
This is not really an Audacity problem.
The first thing I'd try is doing a full system shut-down and reboot.
Did it ever work? If it did, then you could try rolling back to a restore point from before it broke.
If it never worked, or if you don't have any restore points, try searching Google for "Unknown USB Device Descriptor Request Failed" - there are many suggestions of things to try.
roadsterUK
Re: USB Driver
Post by roadsterUK » Sat Aug 25, 2018 8:46 am
You may need to load a driver supplied by the turntable manufacturer.
