Does anyone know the keyboard shortcut to select the entire track that is currently being operated?
If we press "Ctrl + A", we will select all tracks, including tracks that are not currently being operated.
Using a mouse, we can select only by clicking the bar at the left end of the track.
If there is no clip in the track, we can also select it by double clicking.
But, I would like to select it with a keyboard shortcut.
We can select it by pressing "Shift + K" after pressing "Home", but it takes two stages.
This selection also does not exist in the menu. I hope developers to add the option in future updates.
If it so happened, it's easy to set the shortcut.
Best regards,
Keiji
the keyboard shortcut to select the entire track currently being operated
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Re: the keyboard shortcut to select the entire track currently being operated
There are three parts to a selection:
When a track has focus, it's "selectedness" can be toggled with the "Enter" key. If there is no time selection, then pressing Enter can be seen to change whether the info box on the left end of the track is highlighted or not. If there is a time selection, then pressing enter will also toggle that selection in the track.
The following keyboard shortcuts are the relevant ones:
"J", then "Shift + K"
For a full description of "Selection", see: https://manual.audacityteam.org/man/aud ... ction.html
- The start time
- The end time
- A track list (may be one or more tracks)
The track that is currently being operated on has a yellow border. We refer to this as the track that has "focus".
- J (Move cursor to start of audio in selected track(s))
- K (Move cursor to end of audio in selected track(s))
- Shift + J (extend selection to start of audio in selected track(s))
- Shift + K (extend selection to end of audio in selected track(s))
Thank you, steve.
Thank you for your quick and kind reply.
However, I wrote
I think two-stages shortcut is a little bothersome.
And, I need one-stage shortcut to set in programmable app.
"Selecting the entire track currently being operated" is convenient setting even for other than me.
If there is no one-stage shortcut at now, I hope developers to add the option to menu in future updates.
Best regards,
Keiji
However, I wrote
Your answer ["J", then "Shift + K"] takes two stages.We can select it by pressing "Shift + K" after pressing "Home", but it takes two stages.
Best regards,
Keiji
Why can't you use two commands?
In the next release of Audacity (due out in a few weeks), it will be possible to create a macro that selects from the start of the track to the end of the track. It is also possible to set keyboard shortcuts to macros, so the solution will be to create and save the macro, then add a shortcut to it.
Thank you for your reply.
https://allyourinternets.wordpress.com/ ... -firefox/
Though the images in the URL are old, the setting of accept is same in now.
I'm looking forward to the next release.
Best regards,
Keiji
For example, Logitech's SetPoint accepts one-stage shortcut as key-stroke.Why can't you use two commands?
Thank you for the information.In the next release of Audacity (due out in a few weeks), it will be possible to create a macro that selects from the start of the track to the end of the track. It is also possible to set keyboard shortcuts to macros, so the solution will be to create and save the macro, then add a shortcut to it.
Best regards,
Keiji
So you want to configure your mouse to select all of the audio in the current track? If I've understood that correctly, why not just click on the info panel on the left end of the track?keiji wrote: ↑Thu Aug 23, 2018 8:21 pmFor example, Logitech's SetPoint accepts one-stage shortcut as key-stroke.
