Help for Audacity on macOS.
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
Trebor
- Operating System: Windows 8 or 8.1
Post
by Trebor » Tue Aug 28, 2018 9:18 am
TTPDrew wrote: ↑Mon Aug 27, 2018 8:50 pm
... I've tried to install the Noisegate.ny in the same plugins folder where I see my other plugins but it's not showing up as New, Enabled, or Disabled when I try to add in Audacity.
Any idea what I'm missing?
Audacity plugins folder in Windows has moved from it's long time home, see ...
viewtopic.php?p=350889#p350889
I don't know if its location has changed in Macs, (me no speak mac).
TTPDrew
Post
by TTPDrew » Tue Aug 28, 2018 11:26 am
The other plugins that are visible are in the same folder where I put the Noise Gate plugin so it seems like that should work. No idea where else it would go.
- Site Admin
Post
by steve » Tue Aug 28, 2018 12:35 pm
Topic moved to the Mac forum as it has become Mac specific.
TTPDrew wrote: ↑Tue Aug 28, 2018 1:00 am
I had updated to the latest version prior to trying to add the Noise Gate plugin. It's not showing up in my 2.2.2 version,
Do other Nyquist plug-ins show up?
Do you have Nyquist effects in your "Effect" menu (such as "High Pass Filter")?
TTPDrew
Post
by TTPDrew » Tue Aug 28, 2018 12:44 pm
I'm not seeing anything labeled "Nyquist" but I do have an AUHiPass effect. The screenshots show the list of effects available at this point.
- Screen Shot 2018-08-28 at 8.42.08 AM.png (293.47 KiB) Viewed 355 times
- Screen Shot 2018-08-28 at 8.42.23 AM.png (321.84 KiB) Viewed 355 times
- Site Admin
Post
by steve » Tue Aug 28, 2018 1:10 pm
Yes you do have other Nyquist plug-ins installed. "High Pass Filter..." in the bottom part of the Effect menu is one of the standard Nyquist plug-ins that is included in Audacity.
In Finder, right click on "Noisegate.ny" and select "Get Info", then take a screen shot of the Info and post it here.
Post
by kozikowski » Tue Aug 28, 2018 1:17 pm
Shift-Command-4 and draw a box around the panel. It will save a picture on your desktop. Double click it and it will show you what you have.
TTPDrew
Post
by TTPDrew » Tue Aug 28, 2018 1:18 pm
Thanks...here's that screenshot.
- Screen Shot 2018-08-28 at 9.17.25 AM.png (96.07 KiB) Viewed 353 times
- Site Admin
Post
by steve » Tue Aug 28, 2018 1:39 pm
Perhaps Koz can comment (he's more familiar with Mac than I am), but I think the location is wrong.
On my Mac, the shipped plug-ins are in:
Macintosh HD/Applications/Audacity.app/Contents/plug-ins/
My custom plug-ins are in:
/Users/<my-user-name>/Library/Application Support/audacity/Plug-Ins/
TTPDrew
Post
by TTPDrew » Tue Aug 28, 2018 1:55 pm
Interesting, I found a folder with that naming structure and placed the Noisegate.ny file there. It did show up as a new effect but I got this message when I clicked enable.
- Screen Shot 2018-08-28 at 9.53.34 AM.png (98.59 KiB) Viewed 352 times
- Site Admin
Post
by steve » Tue Aug 28, 2018 2:19 pm
Please attach the plug-in file to your reply so that I can check it.
