new 2.2.2 version of audacity
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
mickthefish
- Operating System: Windows XP
mickthefish-will i still be able to use my 2.x version of audacity if i download the 2.2.2 version?
Re: new 2.2.2 version of audacity
By default (and recommended), the 2.2.2 installer will upgrade (overwrite) the previous version of Audacity.
If for any reason you need to go back to an older version, you can simply re-download the older installer and overwrite (downgrade) the 2.2.2 version.
Audacity 2.2.2 is compatible with projects made with earlier versions of Audacity.
If you have a strong reason for having multiple versions installed at the same time, then that is possible, but not generally recommended (unless you are an experienced "beta tester").
You may not want to go back depending on which one. 2.2.1 and maybe 2.2.0 had a serious Project file management problem that could cause show damage.download the 2.2.2 version?
You can download the installer and keep it parked on the side somewhere. You don't have to download it each time.
mickthefish
hi-many thanks for your helpful replies-i will keep my downloaded 2.2.2 version on a mem stick for the time being & open it when I've read more about it on your feedback.have a nice day...thanks mt f.
