Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
LeeX
Post
by LeeX » Thu Aug 09, 2018 8:38 pm
Hi,
Can someone please let me know how I can shift part of the track (not the whole track). In the screenshot below, I just want to shift the highlighted part of the track to left 0.1 second. However after I click the <-> button and move the selected (highlighted) section of the track, the whole track got moved
- section.jpg (521.96 KiB) Viewed 305 times
Thanks & regards,
Lee
DVDdoug
- Forum Crew
Post
by DVDdoug » Thu Aug 09, 2018 9:58 pm
I'm not sure it there's a "best way", but you could copy that section and paste-into a new track where you can freely-align it. After clicking Copy, Generate -> Silence to mute the original selection.
- Site Admin
Post
by steve » Thu Aug 09, 2018 10:03 pm
LeeX wrote: ↑Thu Aug 09, 2018 8:38 pm
Split the selected audio to a new track ("Edit menu > Clip boundaries > Split New")
Then use the
Time Shift tool to nudge it to the left.
LeeX
Post
by LeeX » Sat Aug 11, 2018 3:31 am
Thanks for your information. It solved my problem
If I need to shift a few sections of the recorded track. I assume I just repeat the little trick, right? Is there any limit on how many tracks I can create in the same project?
Not sure whether or not it's doable. It would be great if future releases can let users shift just the portion they select/highlight on the track.
Thanks & regards,
Lee
