Clips with pre-existing, unmoveable envelope control points
xerkon
Operating System: Windows 7
Post by xerkon » Sun Jul 29, 2018 7:35 am
Audacity 2.2.1 - Windows 7
Sorry, I couldn't think of a better title. I clicked on the envelope tool and noticed some of my clips already had a control point at the very end, without me doing anything. I haven't been able to move any of them. It seems to only happen when my clip ends on a label. There's no control point at the beginning of a clip that starts on a label. Anyone else seen this?
2018-07-29 00_32_57-SofS_7Main.png (21.81 KiB) Viewed 102 times
2018-07-29 00_33_41-SofS_7Main.png (4.01 KiB) Viewed 102 times
xerkon
Re: Clips with pre-existing, unmoveable envelope control points
Post by xerkon » Sun Jul 29, 2018 7:43 am
I was going to edit my original post but....am I just missing the edit button?
I found a control point that appeared without there being a label there.
