Changiing the value in effect "Normalize" (Normalize to ...)
юра00
Post by юра00 » Wed Jul 25, 2018 3:36 pm
Is there a combination of keys, instead of a mouse that makes a "blue" field, where the figures of "Normalize" so that you can delete and insert a new value?
waxcylinder
Re: Changiing the value in effect "Normalize" (Normalize to ...)
Post by waxcylinder » Wed Jul 25, 2018 3:46 pm
yes - use the Tab key to tab around the dialog
юра00
Post by юра00 » Wed Jul 25, 2018 5:59 pm
Thank you! Just for some reason, it (Tab) has to be pressed twice. Is it right?
After the first press (1), after the second press (2):
юра00
Post by юра00 » Wed Jul 25, 2018 6:07 pm
Immediately after opening the effect window:
Post by steve » Wed Jul 25, 2018 7:01 pm
Yes, that's right.
юра00
Post by юра00 » Thu Jul 26, 2018 5:48 am
Clear, thank you!
