Project rate.
Project rate.
Is it possible to correct, that immediately after import the figures of project rate in the left bottom corner would set automatically to 48000 Hz, independently of original imported file rate?
- Attachments
- Capture.PNG (38.53 KiB) Viewed 563 times
Re: Project rate.
Importing a file into an empty Audacity project will override Audacity's default project rate. This prevents data loss when working on files that have higher sample rates than Audacity's default, and for single track projects it makes the exported file have the same sample rate of the imported file. If this behaviour is not what you want, then the project rate may be changed manually in the lower left corner of the main Audacity window.
Re: Project rate.
The fact of the matter is that every time you have to manually. It would be better if the program switches itself (of course, if the user sets the appropriate setting) to 48000 Hz. And hardly anyone will import a file with a rate higher than 48000 Hz. The overwhelming majority of files are exported to mp3, and for this format, rate higher than 48,000 Hz can't be put.
Re: Project rate.
In my experience, one needs to keep an eye on the Project Rate field in lower left corner before exporting. I ruined a 32 kHz file last night after mixing down tracks about six times.. when the default Project Rate was 22 kHz because I work lectures and talk shows. But this file had 32 kHz bumper music segments to include. Didn't notice the reduced bandwidth (sampling) until the very end.
-Ed
-Ed
Re: Project rate.
And my experience shows that it is easier to work with a keyboard (hot keys, for example) than with a mouse. And now you can use only mouse.
Re: Project rate.
Re: Project rate.
Is there a key that changes the project rate?! More precisely, allows to switch its value in the lower left corner. How!?
waxcylinder
Re: Project rate.
Re: Project rate.
Here too, there is (Rate), but this is not the same. Dear waxcylinder, changing default rate in preferences doesn't affect on the value in the left corner. It is always equal to original file value.
- Attachments
- Capture.PNG (73.7 KiB) Viewed 505 times
