Stretching the track to full screen in the vertical direction?
юра00
Post by юра00 » Sun Jul 15, 2018 6:42 am
Is there a key, similar to Fit to width, but in the vertical direction? And so, it is necessary to stretch by the mouse, having hooked on the bottom edge.
юра00
Re: Place the track to full screen the vertical direction?
Post by юра00 » Sun Jul 15, 2018 6:45 am
Default position (1), necessary (2).
Re: Stretching the track to full screen in the vertical direction?
Post by steve » Sun Jul 15, 2018 10:02 am
In Audacity 2.2.2:
"View menu > Track Size > Fit to Height (Shift + Ctrl + F)"
The full list of shortcuts is here: https://manual.audacityteam.org/man/key ... rence.html
юра00
Post by юра00 » Sun Jul 15, 2018 11:02 am
Thank you! But this is not quite a full screen. Still, the strip remains unfilled.
Post by steve » Sun Jul 15, 2018 11:16 am
Yes it does - that's the way it is designed to work, so that there is a little room for things below the track, without the need for scrolling.
юра00
Post by юра00 » Sun Jul 15, 2018 11:33 am
Thank you! It's very good, at least in perspective, to have a really full screen, but, as I understand, this task is not among the first.
Post by kozikowski » Sun Jul 15, 2018 2:13 pm
Your illustrations suggest you don't want a graphic solution so it looks pretty. You want to make the show louder.
Effect > Amplify. The default setting ([_]Allow Clipping - de-select) will make the blue waves fill the screen top to bottom and will stop increasing the volume just before the sound distorts.
юра00
Post by юра00 » Mon Jul 16, 2018 4:35 pm
Sorry, but I don't need to amplify the signal at all.
Post by kozikowski » Tue Jul 17, 2018 2:46 am
Worth a shot.
