Really Bad Recording Problem
OggOrbisRecords
Re: Really Bad Recording Problem
Post by OggOrbisRecords » Tue Dec 18, 2007 3:47 pm
ok did you go into preferences and turn off the setting to make it do that before you even bothered with things outside of the computer? there is a setting to have it drop down like that that you can turn off and on
Paul
Lifestream
Post by Lifestream » Tue Dec 18, 2007 9:36 pm
stevethefiddle wrote:Your answer lifestream, was a few posts previously in this thread:
you-ff wrote:Hi,
What recording device is displayed in Audacity? I had your described problem until I figured that the recording source should be either "Line in" or "Microphone". I had it set to "Wave Out Mix" which, as the title suggests, is the combined sounds in the sound card. Oops.
Ok, I've done all of that already. It's still mxing all the sounds in the soundcard. :(
Lifestream
Post by Lifestream » Tue Dec 18, 2007 9:43 pm
OggOrbisRecords wrote:ok did you go into preferences and turn off the setting to make it do that before you even bothered with things outside of the computer? there is a setting to have it drop down like that that you can turn off and on
In Audacity, yes. Te recording device is set to Line in/Mic in.
Yeah, even if I have my speakers and mic off; headphones unplugged - if I record anything in ANY sound recorder, it will record all the sounds that are playing on my computer.
Post by kozikowski » Wed Dec 19, 2007 6:21 am
Welcome to the mysteries of the Windows Control Panels.
