Adding Plugins
Re: Adding Plugins
As requested
And yes........all items are checked in preferences 'effect'
12:56:28: Audacity 2.2.2
12:56:28: Warning: Critical Nyquist files could not be found. Nyquist effects will not work.
12:56:29: Trying to load FFmpeg libraries...
12:56:29: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
12:56:29: Looking up PATH environment variable...
12:56:29: PATH = 'C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;%SYSTEMROOT%\System32\OpenSSH\;C:\Users\rhenn\AppData\Local\Microsoft\WindowsApps'
12:56:29: Checking that '' is in PATH...
12:56:29: FFmpeg directory is in PATH.
12:56:29: Checking for monolithic avformat from 'avformat-55.dll'.
12:56:29: Error: Failed to load shared library 'avformat-55.dll' (error 126: the specified module could not be found.)
12:56:29: Loading avutil from ''.
12:56:29: Error: Failed to load shared library '.dll' (error 126: the specified module could not be found.)
12:56:29: Loading avcodec from ''.
12:56:29: Loading avformat from 'avformat-55.dll'.
12:56:29: Error: Failed to load FFmpeg libraries.
12:56:29: Error: Failed to find compatible FFmpeg libraries.
Re: Adding Plugins
Have a look in "C:\Program Files (x86)\Audacity\Plug-Ins\"
Do you see a bunch of files with file extension ".ny"
For example:
For example:
Code: Select all
adjustable-fade.ny
beat.ny
clipfix.ny
crossfadeclips.ny
Re: Adding Plugins
The 'Plug Ins' file is empty
Bob H
Bob H
Re: Adding Plugins
Hooray, we've found the problem.
Download the "Audacity 2.2.2 installer " from here: https://www.audacityteam.org/download/windows/
When it has downloaded, double click on the .EXE file to run the installer.
When the installation is complete, check again in "C:\Program Files (x86)\Audacity\Plug-Ins\"
Re: Adding Plugins
Ok.......see attached error message during intall
- Attachments
- Screenshot (7).png (442.43 KiB) Viewed 490 times
Re: Adding Plugins
You probably need to right click on the installer and select "Run as administrator" (I rarely use Windows, so if that's not quite right you may need to Google)
Re: Adding Plugins
Should I uninstall the previous version before installing the new one?
Re: Adding Plugins
Yes you can do that.
Re: Adding Plugins
Hi
Reinstalling solved the problem, crossfade is now listed in the effects queue.
Always a pleasure dealing with you folks.
Thank you
Bob H
Thank you
Bob H
waxcylinder
Re: Adding Plugins
Thanks for reporting back Bob - glad we solved your problem and you've got the crossfade effect
