Adding Plugins
rj7500
Adding Plugins
Post by rj7500 » Mon Jul 02, 2018 4:20 pm
I'm trying to use the 'add/remove plug ins' feature on my desktop. I 'enabled' the Crossfade tracks plug in but when I save, it doesn't appear in my list of available effects.
Windows 10
Audacity 2.2.2
Thanks folks in advance
Bob H
Trebor
Re: Adding Plugins
Post by Trebor » Tue Jul 10, 2018 2:17 am
rj7500
Re: Adding Plugins
Post by rj7500 » Wed Jul 11, 2018 9:02 pm
If Crossfade tracks is a native effect.......it still does not appear on my list of available effects.
Bob H
Re: Adding Plugins
Post by steve » Thu Jul 12, 2018 12:46 pm
Try resetting Audacity completely:
First, close Audacity, then,
Go to "Users/<your user name>/AppData/Roaming/audacity/"
and delete the 3 files:
audacity.cfg
pluginregistry.cfg
pluginsettings.cfg
then restart Audacity and you should find "Crossfade Tracks" in the "Effect" menu (in the lower part of the list below the divider).
rj7500
Re: Adding Plugins
Post by rj7500 » Thu Jul 12, 2018 1:41 pm
Hi Steve
I followed your instructions and deleted the files. I restarted Audacity and opened the effects menu and still no Crossfade, as the attached screenshot will show.
Screenshot (6).png (284.58 KiB) Viewed 536 times
Re: Adding Plugins
Post by steve » Thu Jul 12, 2018 2:15 pm
For some reason you don't have any Nyquist plug-ins listed at all. That shouldn't happen.
How did you install Audacity (describe step by step instructions so that I can install exactly the same version of Audacity in exactly the same way as you did).
rj7500
Re: Adding Plugins
Post by rj7500 » Thu Jul 12, 2018 2:26 pm
The original installation was a while ago, but I installed it from the website. Subsequently, I upgraded as they became available.
Bob H
Re: Adding Plugins
Post by steve » Thu Jul 12, 2018 2:30 pm
Where is Audacity installed?
On Windows 64-bit it is usually installed in "C:\Program Files (x86)\Audacity"
rj7500
Re: Adding Plugins
Post by rj7500 » Thu Jul 12, 2018 2:32 pm
Yes, that's the correct path.
Bob H
Re: Adding Plugins
Post by steve » Thu Jul 12, 2018 2:44 pm
Need to do some investigating as it's not clear why this is happening.
If Audacity is open, shut it down and restart it. Then look in "Help > Diagnostics > Show Log".
Copy and paste the entire contents into your reply.
In "Edit menu > Preferences > Effect", all of the options should be ticked (like this: https://manual.audacityteam.org/man/eff ... ences.html). Are they?
