Cannot Record--Help!!
I got a new computer using WIN XP professional. Downloaded Audacity but when sound comes through my speakers, all I get is a straight tone...no recording. In my old computer I used to use Stereo Mix but Stereo Mix is not available on the tool bar. All i see is Rear Mic, Michphone, Line In. I have done to the control panel and changed everything I know but cannot record. What to I need to do or what am I missing?
Dukey
Dukey
Re: Cannot Record--Help!!
I suppose we need to find out what you're trying to do. You didn't say.
I can't record......what?
Which version of Audacity?
I am trying to record music. I am using Audacity Stable 1.2.
Honey
Honey
<<<I am trying to record music.>>>
Thank you. Now we need the left-brain engineering version of that. I connected a wire.....?
In the past when I heard music on the internet or even a program on the internet I used to use Audacity to capture the music or program, then save the information to my hard drive. Since I have a new computer I cannot record the music or programs. In the past I used stereo mix to record. Stereo mix is not one of the options any more. What can I use to capture the recordings?
Thanks
Honey
Thanks
Honey
<<<In the past I used stereo mix to record.>>>
Oh, beans. I'm not good with those problems. Did you go from Windows XP to Windows Vitsa? Or Windows 2000 to Windows XP? Somebody else wrote how to get around that problem. I'll see if I can locate it.
honey,
This wiki page should help you out, there's a big grey box right at the top of this link:
That page should tell you how to set your driver software up right, but you might need new drivers, in which case this page will help:
http://audacityteam.org/wiki/index.php? ... ce_Drivers
If you have sigmatel audio, try steps 2-4 listed here: http://forum.notebookreview.com/showthr ... stereo+mix
