Poor sound on export
Re: Poor sound on export
Post by kozikowski » Sat Jun 30, 2018 5:49 pm
There may be other things to try. I said there are very serious problems with that clip that most people may not be able to hear.
Effect > Equalization: Low Rolloff for Speech, Length about 5000 > OK
Effect > Compress Dynamics (Chris):
Screen Shot 2018-06-30 at 10.31.44.png (37.1 KiB) Viewed 146 times
This is a before and after of one of my presentations. It switches at six seconds.
CurdsAndWheyChrisCompressed.wav
(3.17 MiB) Downloaded 11 times
Both of those tools have sticky preferences. Once you set the tools the way you want, the settings tend to stick that way, so they're really easy to use.
aymanzone
Post by aymanzone » Mon Feb 22, 2021 11:25 pm
hi, I know this is not related but maybe a little. I'm also experiencing lose of volume when exporting to MP3/WAV. I'm not sure if it's a bug in the software or just growing pains. But I'm using Windows Payer and Windows 10 OS and Recording volume is 1.0.
I just thought I would put it out there if you are still having problems, your not alone. Note that I'm newbie to this.
jademan
Forum Crew
Post by jademan » Tue Feb 23, 2021 10:44 pm
I suspect you are right that your problem is not related.
Why do you think you are experiencing a loss of volume? Do you want to record a 10-second sample then post the .WAV and .MP3 files? Before you export take a snapshot: Tools > Screenshot > Capture Full Window.
Edited: Please disregard. I see you have posted this issue in a different thread here viewtopic.php?f=46&t=116017
where you have already received some replies.
