where do I find the noise gate plugin
Help for Audacity on macOS.
NilaB
Post by NilaB » Thu Jun 21, 2018 3:57 pm
I am currently handling each great by hand....yeah, I know....there is a better way, but where can I find the plug ins and will Waves NS! work with audacity?
Trebor
Re: where do I find the noise gate plugin
Post by Trebor » Thu Jun 21, 2018 6:40 pm
NilaB wrote:...where can I find the plug ins ...?
A free Audacity-specific noise-gate is here ...
https://wiki.audacityteam.org/wiki/Nyqu ... Noise_Gate
Post by steve » Thu Jun 21, 2018 10:08 pm
Based on what others have posted on this forum, Waves plug-ins are often incompatible with Audacity.
insp234
Noise Gate Plugin in problems
Post by insp234 » Sun Sep 01, 2019 2:06 pm
Hi - Can someone please help!
The outcome I am looking for is to remove or reduce the sounds of my breathing from an audio file.
I am trying to download the Noise Gate plugin for audacity, however I am receiving this message.(Screenshot attached)
How do I solve this?
I am using Mac High Sierra 10.13.6 and Google Crome.
Screen Shot 2019-09-01 at 13.39.07.png (535.63 KiB) Viewed 19290 times
Post by steve » Sun Sep 01, 2019 3:25 pm
You need to download the file without opening it.
The fact that the screenshot says "Noisegate(3).ny", it looks like you have already downloaded the file several times. Look in your download folder and you should see the file "Noisegate.ny".
To install the plug-in, see: https://manual.audacityteam.org/man/ins ... st_install
Post by kozikowski » Sun Sep 01, 2019 6:15 pm
@ insp234
When you do get it installed and get it running, post back with the results and how you got there. You didn't say you were reading for audiobooks, but that is a common failure for new readers. It would be good to get first-hand experiences with the tools, particularly if you got everything to work perfectly.
mikep
Post by mikep » Mon Apr 13, 2020 3:14 am
I tried downloading the noise gate plug-in several times from the download site, and the only thing that is download is the help text. The plug-in doesn't download. I've done a spotlight search for the plug-in on my computer and it's no where to be found. Is there some special way to download it?
Post by steve » Mon Apr 13, 2020 9:01 am
Does that "help text" begin with:
;nyquist plug-in
;version 3
;type process
If so, then that is not "help text" it is the plug-in. Nyquist plug-ins are just text files with the file extension ".ny" rather than ".txt".
Installation instructions for Nyquist plug-ins on Mac: https://manual.audacityteam.org/man/ins ... st_install
mikep
Post by mikep » Mon Apr 13, 2020 9:00 pm
I discovered that for some reason I could not dowload the plug-in in Safari. Firefox worked
