. Hello i have maked a record, the record are qualitity perfect. I just need to amplify my record.
But by amplifying the noises they reveal themselves. How can i amplify my record without amplify the noises?
Unlistenable noises
Daniel_Figueiredo
Re: Unlistenable noises
Unfortunately not possible : both signal & noise will be amplified.Daniel_Figueiredo wrote: How can i amplify my record without amplify the noises?
However you can reduce the noise after amplification using Audacity's Noise Reduction.
( Use sparingly, as it can distort the signal )
This is a common problem with people reading for audiobooks for the first time. They can get the right volume, or the low background noise, but not both. They need Effect > Noise Reduction, too.
Please note Noise Reduction works in two steps. Drag-select a short part of the show with no performance in it—background noise. Effect > Noise Reduction > Profile. Now Audacity knows what to reduce. Select the whole show and Effect > Noise Reduction. Start with the default values.
Daniel_Figueiredo
Ok. Thanks for the help. when i have writed this post i have some hope of that whould be possible. Just another tip.
We can measure the right level of db of noise in the playback measure of dbs if constant.
Here
Here
Reason: Upload images for greater reliability
