echo when applying effects
Help for Audacity on macOS.
tomfuller
Post by tomfuller » Mon Jun 11, 2018 3:58 pm
I am trying to record my voice, via a mixer and microphone, accompanied by an imported .mpg. It seems to work fine, until I play it back and apply effects (compressor, equalization, normalize). Then it adds an echo to the stereo accompaniment track, even tho I didn't select it. I tried selecting only the mono vocal track, when applying effects. The vocal track is grayed, and the stereo accompaniment tracks appear selected with clocks on the background. I'm new at this, and frustrated. How do I select only the vocal track to apply effects? And why does it add echo? Thanks. Tom in Texas
Trebor
Re: echo when applying effects
Post by Trebor » Mon Jun 11, 2018 4:38 pm
tomfuller wrote:The vocal track is grayed, and the stereo accompaniment tracks appear selected with clocks on the background
To get rid of the clocks see ... https://manual.audacityteam.org/man/syn ... roups.html
tomfuller
Post by tomfuller » Mon Jun 11, 2018 6:05 pm
Ok...sorry I'm dense. So, if the clocks are in the background of the accompaniment tracks, does that mean the accompaniment tracks are selected, and subject to any effects I apply? I want to leave the accompaniment just as it is, and apply effects only to my voice, which is on a third mono track. Thanks. TnT
billw58
Post by billw58 » Mon Jun 11, 2018 11:49 pm
Please see this page in the manual.
Effects are applied to selected audio. The clocks (sync-locked track groups) are irrelevant. Make sure that you select only the track you want to apply the effect to.
-- Bill
Trebor
Post by Trebor » Tue Jun 12, 2018 12:29 am
tomfuller wrote:I am trying to record my voice, via a mixer and microphone, accompanied by an imported .mpg.
It seems to work fine, until I play it back ... Then it adds an echo ...
Try unchecking "Software playthrough of input" in Audacity preferences ...
