Red triangle on timeline and not recording
Help for Audacity on macOS.
mytrae
Post by mytrae » Sun Jun 10, 2018 9:33 pm
I can't record because a red triangle appeared on the timeline with "Timeline actions disabled during recording" even though I'm not recording. I tried closing the file and Audacity but the setting seems to be stuck.
I'm using a Macbook Pro 10.13.3 and Audacity 2.2.2
billw58
Re: Red triangle on timeline and not recording
Post by billw58 » Mon Jun 11, 2018 1:58 pm
Please see this page.
The red triangle is the recording cursor. You are probably in record-pause. Try pressing the stop button.
-- Bill
[email protected]
Post by [email protected] » Sat Oct 06, 2018 1:49 pm
I have red triangle on timeline and cannot record. Quitting Audacity and selecting the pause button have not enabled me to continue recording. Please advise.
billw58
Post by billw58 » Sat Oct 06, 2018 3:40 pm
Please check the menu Transport > Transport Options and make sure that "Sound Activated Recording" is not checked.
-- Bill
[email protected]
Post by [email protected] » Sat Oct 06, 2018 10:27 pm
Hi Bill, Thanks for the reply, I have done all you suggested and still not able to record.
YoungLion
Post by YoungLion » Sat Dec 01, 2018 4:23 am
I'm having this problem as well, please HELP, I've tried everything and still not able to record. I even uninstalled and reinstalled but still can't record. This is so frustrating.
Post by steve » Sat Dec 01, 2018 3:20 pm
Please save the "Audio device info" (see: https://manual.audacityteam.org/man/hel ... evice_info) and attach the saved file to your reply.
See here for how to attach a file to your forum post: viewtopic.php?f=49&t=64936
dwardo14
Post by dwardo14 » Thu Sep 10, 2020 8:19 am
actually using windows 10 but the same thing is happening
