Scroll wheel zoom? And where did Check Dependencies go?
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
RichR
Post by RichR » Sat Jun 09, 2018 6:04 pm
1. Feature request: I'd like to Zoom In and Zoom Out using the mouse scroll wheel.
2. On earlier versions, Check Dependencies... was on the File menu. Where did it go?
waxcylinder
Re: Scroll wheel zoom? And where did Check Dependencies go?
Post by waxcylinder » Sat Jun 09, 2018 6:09 pm
RichR wrote:2. On earlier versions, Check Dependencies... was on the File menu. Where did it go?
Help > Diagnostiscs > Check Dependencies
In the front page of the Manual there is a link near the top for "What's new ..."
Which for 2.2.2 takes you to: https://manual.audacityteam.org/man/new ... lease.html
RichR wrote:1. Feature request: I'd like to Zoom In and Zoom Out using the mouse scroll wheel?
You can already - see: https://manual.audacityteam.org/man/zooming.html#wheel
Post by kozikowski » Sat Jun 09, 2018 6:11 pm
Click somewhere.
Control-Mouse Wheel on Windows.
Command-Mouse Wheel on Macs.
RichR
Post by RichR » Sat Jun 09, 2018 6:40 pm
waxcylinder wrote: Help > Diagnostiscs > Check Dependencies
Which I would have found if the Manual was searchable. (The index is awfully sparse.)
Thanks!
Post by kozikowski » Sat Jun 09, 2018 7:40 pm
I didn't search. In this particular case: From a forum window > On-Line Manual
Reference (on the left) > Index (scroll down) > Zoom. Scroll down until I hit it.
My favorite problem is the Add-On and Home-Made Filters. Those are abysmally hard to find, and I know they're there.
waxcylinder
Post by waxcylinder » Sun Jun 10, 2018 11:30 am
Tell me about it :roll: It's a long story, is searchable ...
And yes I know the Index is sparse (it was worse a while back, I found a bit of time to improve for that last release 2.2.2) :oops:
If I can't remember where a command is in the menu tree, I go to Edit > Preferences and select the Keyboard tab
Then I use the Search box - in replying to this post of yours I just typed in "dep" and it showed me ;) 8-)
