Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
Trebor
- Operating System: Windows 8 or 8.1
Post
by Trebor » Wed Jun 06, 2018 8:02 am
sunnyard5666 wrote:The CD replays perfectly on the computer but will not play on any other CD players that I have which, admittedly, are quite old.
Old stand-alone CD-players don't play mp3-format audio files.
Here's how to make a CD which is playable on stand-alone CD players ...
https://manual.audacityteam.org/man/bur ... _a_cd.html
roadsterUK
Post
by roadsterUK » Wed Jun 06, 2018 8:05 am
Presumably you transferred the files to CD simply by copying them. Most CD players will not recognise the windows file format so you require software which will take your files and write them in the standard format for an audio CD. For example there is an optional component for Foobar 2000 called audio CD writer. Foobar2K is free software although not open source like Audacity.
waxcylinder
Post
by waxcylinder » Wed Jun 06, 2018 11:00 am
sunnyard5666 wrote: ... I've managed to record some old audio tapes onto the computer as MP3 files and transferred them to CD. I haven't a clue what MP3 means.
MP3 is a compressed format (where some of the audio information is thrown away) mainly for use on small portable playback devices -
https://en.wikipedia.org/wiki/MP3
For making CD's you need WAV files - and Trebor's instructions
