deleted all the vocals
TrillDill
Post by TrillDill » Tue May 22, 2018 4:21 am
i just closed a project and when i went to open it all my stereo tracks were gone like the silence tool was used on everything is this an error that happens, if anyway you could add the sound back to all the stereo tracks that would be really helpful thanks.
pressed.aup
(93.65 KiB) Downloaded 52 times
Trebor
Re: deleted all the vocals
Post by Trebor » Tue May 22, 2018 4:59 am
TrillDill wrote:ATTACHMENTS pressed.aup (93.65 KiB)
files ending ".aup" don't contain any audio: they just contain references to the audio stored on your computer ...
this is the content of "pressed.aup (93.65 KiB)"
No audio in 'aup' files.png (58.39 KiB) Viewed 427 times
Post by kozikowski » Tue May 22, 2018 2:21 pm
An Audacity Project is an AUP file telling Audacity what to do with the sound work inside the _DATA folder. The AUP is the manager file. They both have to be there and in the same location or folder, and the names have to be the same.
This was a show called "My Music." You would have both of those with your name instead of mine.
Can you find both file and folder?
The AUP file suggests you have Audacity 2.1.1. Is that true?
TrillDill
Post by TrillDill » Sat May 26, 2018 4:07 pm
yes i have both the .aup file and data file in the same locations and i do have the 2.1.1
TrillDill
Post by TrillDill » Mon May 28, 2018 12:22 am
kozikowski wrote:An Audacity Project is an AUP file telling Audacity what to do with the sound work inside the _DATA folder. The AUP is the manager file. They both have to be there and in the same location or folder, and the names have to be the same.
do i need to do something with the files or send them to you
Post by kozikowski » Mon May 28, 2018 2:56 am
You can't send it. The audacity forum only allows about 2MB of "stuff."
Open the Project. Is it in Stereo—coming from both speakers with everybody singing?
Tracks > Mix > Mix Stereo to Mono.
Play it. Did the singers vanish?
TrillDill
Post by TrillDill » Thu May 31, 2018 3:34 am
I did that and still heard nothing ill give you more details, the client crashed one day while i was recording when i reopened audacity it asked me to recover so i did but then when it recovered it showed all the audio that was recorded including the beat silenced it still shows the length in which they were recorded the panning and gain settings but all the audio is silenced... I also had other projects i hadnt saved that crashed with it but the audio on those projects werent silenced they were the same as they were before the crash, its the only project that got silenced
