Audacity Crashing...
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
hmahmoud
Post by hmahmoud » Sun May 20, 2018 7:10 pm
Hi, I'm running MacOS 10.12.6 and Audacity keeps crashing with me as well. I get the following:
Process: Audacity [31389]
Path: /Applications/Audacity.app/Contents/MacOS/Audacity
Identifier: org.audacityteam.audacity
Version: 2.2.2.0 (2.2.2.0)
Code Type: X86 (Native)
Parent Process: ??? [1]
Responsible: Audacity [31389]
User ID: 502
Date/Time: 2018-05-20 12:03:42.212 -0700
OS Version: Mac OS X 10.12.6 (16G1114)
Report Version: 12
Anonymous UUID: 47F43576-F029-DD4D-C57E-65F9E32784F1
Sleep/Wake UUID: A3988155-B93A-49F3-B5D1-B0FC2077E772
Time Awake Since Boot: 89000 seconds
Time Since Wake: 1400 seconds
System Integrity Protection: enabled
Crashed Thread: 11 com.apple.audio.IOThread.client
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
Assertion failed: (!err), function AudioIOProc, file /Users/paullicameli/GitHub/audacity/lib-src/portaudio-v19/src/hostapi/coreaudio/pa_mac_core.c, line 2482.
Any ideas? I tried deleting Audacity and the folder under ~/Library/Application Support/audacity as suggested in other posts but that didn't work. Thanks!
waxcylinder
Re: Audacity Crashing...
Post by waxcylinder » Mon May 21, 2018 9:16 am
keeps crashing when you do what?
What are the steps to reproduce?
hmahmoud
Post by hmahmoud » Thu May 24, 2018 6:02 pm
It crashes whenever I try to record. So all I need to do is click on the record button. Sometimes it will crash after a couple seconds, other times after a minute or so. Thanks!
AltonDex
Post by AltonDex » Sun May 27, 2018 2:10 am
hmahmoud wrote:It crashes whenever I try to record. So all I need to do is click on the record button. Sometimes it will crash after a couple seconds, other times after a minute or so. Thanks!
mahmoud, I keep getting same crash when record is pressed. hoping there is a fix for this.
Paul L
Post by Paul L » Sun May 27, 2018 3:49 am
What version of Audacity, please?
hmahmoud
Post by hmahmoud » Wed May 30, 2018 11:01 pm
I have the latest, 2.2.2.
Marvinsam3
Post by Marvinsam3 » Mon Jun 18, 2018 4:26 am
I am having the same problem. It records for a few seconds and then quits.
Audacity 2.2.2
hmahmoud
Post by hmahmoud » Tue Jun 19, 2018 3:52 pm
Just to update the group (in case it helps anyone), but I tried again on a new Macbook Pro that I recently got and it worked fine (on 2.2.2) and was able to go through with the full recording of the cassette tape. So if you have access to a newer Mac, try that.
