Focusing on tracks after alt+tab / effects window popping?
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Non
Operating System: GNU/Linux other
Post by Non » Fri May 18, 2018 11:23 pm
Hello dear devs. Been using Audacity for a long time, almost seven years. Love the software, appreciate your work. :)
Got too used to autofocus on tracks, and now it's gone, perhaps this feature was lost in Dark Audacity merging process..
Expected behaviour is:
1. I alt+tab / pop effect window.
2. Autofocus gets track selected.
3. I could use keyboard arrows / pop another effect window right after (I bound them on hotkeys 1,2,3,etc).
Current behaviour is:
2. Autofocus gets some pane selected.
3. By using hotkeys (1,2,3) to launch other effects I override project's sampling frequency, because the only pane I still got enabled is 'selection pane'.
4. Revert it back, click into tracks subwindow... and press the hotkey again.
This is frustrating. :( Could you fix it?
Version is 2.2.1 in debian testing.
Re: Focusing on tracks after alt+tab / effects window poppin
Post by steve » Sat May 19, 2018 9:24 am
Non wrote:1. I alt+tab / pop effect window.
Not sure what you mean. Do you mean "i + Alt + Tab", or that: You press "Alt+Tab" ?
Either way, that's not a standard Audacity shortcut. "Alt + Tab" is generally reserved by the OS window manager for switching between windows.
Non
Post by Non » Sat May 19, 2018 4:21 pm
Picture 1
Picture 2
Picture 3
I hope pictures will explain better. :?
Post by steve » Sun May 20, 2018 7:45 am
OK, I see what you mean.
Which version did you have where this was not a problem?
Non
Post by Non » Sun May 20, 2018 8:50 pm
I've compiled 2.1.3 on Debian Testing with *-dev packages. Couldn't get audio interface to work, but I got no pane autofocus issues on 2.1.3.
Then I compiled 2.2.0, and pane autofocus issue was there. So looks like it was introduced in 2.2.0.
I also tested previous builds on windows 7. 2.1.2, 2.1.3, 2.2.0, 2.2.1 did fine. Track was the only thing it had focused. :?
