Problems with Bias Fx VST Plugin windows 10
Para discutir de Audacity en Español
ImagePor favor tenga en cuenta que la mayor parte del personal de Audacity sólo habla Inglés, por lo que no podemos garantizar que sus preguntas en español sean respondidas.
Si su pregunta no ha sido contestada, y puede escribir/leer en Inglés, por favor pregunte en el área en Inglés correspondiente a su sistema operativo y versión de Audacity. Si es posible, por favor, responda a su pregunta en el foro en español y dar allí la dirección web de la pregunta que realizara en el Foro de Inglés.
rodspin
Post by rodspin » Sat Jan 27, 2018 8:02 pm
I need help because im recording my guitar with Audacity and Bias FX VST plugin , in the first case i instaled succesfully Bias FX 32 bites version and vst plugin is eneable to use but some problems emerge because my operative system have 64 bites so i unistaled the bias fx 32 bites and audacity ( newest version) and reinstaled but this time with the bias fx 64 bites version ,so i put the vst in the plugins carpet of audacity and run the program and i pick the option enable / disable effects the program recognize the plugin as a new one but when i pick the enable option audacity dont apply the vst plugin in the list of effects so i dont know how can make it work!!! please help me or give me a patch to solve the problem
thanks for reading me!!
Contact:
Re: Problems with Bias Fx VST Plugin windows 10
Post by steve » Mon Feb 26, 2018 2:57 pm
Audacity is currently a 32-bit application on Windows, so VST plug-ins must be 32-bit.
As you are able to write in English, I would suggest that you post to the English part of the forum in future as reply are usually much quicker there.
