It’s not quite that simple. If you upgrade Audacity from an older version, then you will probably still have Silence Finder and Sound Finder. Also, because most Linux users get their software from their distribution’s repository, in many cases they will be using a slightly older version of Audacity, which may still have these plug-ins.
There’s a note in the alpha version of the manual (which will be the next release version), that Sound Finder and Silence Finder are no longer included.
I knew that was coming!
My first thought was that the Google Bots just hadn’t got around to reindexing the Wiki pages, but then I thought too that you (Audacity Forum/team) are pretty good about updating and re-linking pages.
I am glad that I thought to search the forum, because I am now wading into labels, thanks to Rose’s post.
Thanks, Steve
You’re not kidding! “Note that the peak level will usually be lower than the peak level.”
You will find this here Label Sounds - Audacity Manual under the heading “AVERAGE LEVEL”.
Cheers
Chris
Average level: > The threshold is measured as the absolute average level for each 10 ms. This setting may help avoid labeling clicks in vinyl recording. Note that the average level will usually be lower than the peak level.
