Where are all the plug-ins ?
I went to my old version of Audacity and noticed that when I open the effects menu few of the effects were there. I enabled all the plug-ins but they do not show in the effect menu. Then I uninstalled my version and down loaded the latest version but the same thing happens. :confused:
The latest version of Audacity for Windows is available in 32 & 64 bit ā€¦
You need the 32-bit version if you want to use old 32-bit plugins
Thanks but I down loaded the 32 bit version and I still donā€™t have plug in appear under Effects .
You have to enable the plugins before they appear on the effects list ā€¦
https ://manual.audacityteam.org/man/manage_effects_generators_and_analyzers.html
If you updated from a very old version of Audacity, note the plugins are now to be placed in a different folder ā€¦
Users\<username>\AppData\Roaming\audacity\Plug-Ins
https://manual.audacityteam.org/man/installing_effect_generator_and_analyzer_plug_ins_on_windows.html
Could we have all plug-ins installed with audacity made available by default, please?
It simply states [enable them] on https://manual.audacityteam.org/man/classic_filters.html with no obvious explanation as to why they are initially disabled.
On a clean installation of Audacity, the following effects and plug-ins are enabled by default:
Adjustable Fade
Contrast
High-Pass Filter
Nyquist Prompt
Sample Data Import
Amplify
Crossfade Clips
Invert
Paulstretch
Silence
Auto Duck
Crossfade Tracks
Label Sounds
Phaser
Sliding Stretch
Bass and Treble
Delay
Limiter
Plot Spectrum
Spectral Delete
Beat Finder
Distortion
Loudness Normalization
Pluck
Spectral edit multi tool
Change Pitch
DTMF Tones
Low-Pass Filter
Regular Interval Labels
Spectral edit parametric EQ
Change Speed
Echo
Repair
Spectral edit shelves
Change Tempo
Fade In
Noise Gate
Repeat
Tone
Chirp
Fade Out
Noise Reduction
Reverb
Tremolo
Studio Fade Out
Noise
Reverse
Truncate Silence
Click Removal
Find Clipping
Normalize
Rhythm Track
Vocal Reduction and Isolation
Clip Fix
Filter Curve EQ
Notch Filter
Risset Drum
Vocoder
Compressor
Graphic EQ
Nyquist Plug-in Installer
Sample Data Export
Wahwah
It is possible that this can get messed up if more that one version of Audacity is installed at a time.
ā€œClassic Filtersā€ and ā€œMeasure RMSā€ are shipped with Audacity but are disabled by default.
  • Measure RMS is included as an example for anyone looking to develop their own Nyquist plug-ins.
  • Classic Filters is potentially useful for users that have substantial knowledge about IIR filters, but is potentially confusing for the majority of users.
