Silence Finder
Hi folks, enjoying the new version 3.0.2 so far. Just one question. Regarding the “silence finder”, has that changed ? I couldn’t find it, but I did find a function called “truncate silence”. I’m assuming that has taken over from previous version ?
In addition to jademan’s comment:
  1. Documentation for the new “Label Sounds” plug-in is here: https://manual.audacityteam.org/man/label_sounds.html
  2. If you specifically want to use the old “Silence Finder” Nyquist plug-in, it is available here: https://wiki.audacityteam.org/wiki/Nyquist_Analyze_Plug-ins#Silence_Finder
    Installation instructions are here: https://manual.audacityteam.org/man/installing_effect_generator_and_analyzer_plug_ins_on_windows.html#nyquist_install
Thanks very much for the reply Jademan
And thanks Steve also. Greatly appreciated.
