[Bug] App freezes while editing
I’m already upgraded to version 3.x of audacity because the version that I use is really old (2.4.2)
I’m upgraded to latest version of audacity, after opening. the app suddenly freezes, i closing it via start menu. it’s showed but it refused to press it. i forced to kill it using task manager. after restarting. the problem same again. i finally have a backup setup file to downgrade this version.
i reporting this issues and hopefully the next version will fix that, i don’t have a screenshot about that, sorry.
Ensure that you have 3.0.2 and not 3.0.0 (3.0.2 was released soon after 3.0.0).
Look in “Help menu > About Audacity” for the exact version number.
This problem sounds very similar to a problem several users with Japanese and Chinese character sets were having that started with a recent Windows update. What language are you using in Audacity? Does switching to English change anything?
I using english and latest audacity version, any solutions?
I will try to update it, hopefully it will fixed
Well, updated and returned back to english. still freezes (running but can’t response)
using Audacity 3.0.2
Please check to see if you have the Windows update: KB4571744
