Hey!
Since the last update I am working with an English GUI, before I worked with German GUI. I have a problem which I only have in with the English setting: The last effect settings are not saved or reset. I am not sure if this is a problem of version 3 or if it existed before…
The following things I can do to reprocude:
Import audio → Apply limiter with -5db e.g., close program, don’t save.
The next time I open the program, the limiter is still set to -5d.
I import audio again, apply noise gate and change some noise gate settings, close program, don’t save.
When I now reopen the program, import audio and want to use the limiter, it is reset to -3db.
As I said, with a German GUI the problem doesn’t exist.
I noticed, that the decimal splitter changes from , (German) to .(English), maybe the localization is a problem somehow?
Also the effects below the line are still in German language:
https://ibb.co/8BHj9rQ
I have a German Windows 10 Pro 2004 and Audacity 3.0.2.
If you need any more information please let me know.
Thank you and best regards
Matthias
