No macro-output folder
Feedback and Reviews for Audacity 3.x
This board is ONLY for general feedback and discussion about Audacity 3.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Manjel
Re: No macro-output folder
Post by Manjel » Thu Apr 08, 2021 3:37 pm
steve wrote:
Thu Apr 08, 2021 9:39 am
Manjel wrote:
Wed Apr 07, 2021 11:17 pm
because the imported file was already in a folder called "macro-output".
Ah ha. I thought there must be some missing details.
I can reproduce the problem by first running the macro with:
Code: Select all
Import2:Filename="<some location>/audiofile"
and then again with:
Code: Select all
Import2:Filename="<some location>/New Folder/audiofile"
Is that what you are doing?
Basically yes. But if you were to use the code
Code: Select all
Import2:Filename="<some location>/<macro-output>/audiofile"
it does not create a new macro-output folder at the import location, even if it is the first time you apply the macro. Instead it just overwrites the file that is located at "<some location>/<macro-output>"
Manjel
Post by Manjel » Fri Apr 09, 2021 4:11 pm
Any chance a fix will make it into the next release?
jademan
Forum Crew
Post by jademan » Sat Apr 10, 2021 8:49 pm
A solution for this issue will be included in 3.0.1 release of Audacity, which is currently scheduled for the end of this month.
There is an 3.0.1 RC01 release candidate available for testing here: https://www.fosshub.com/Audacity-devel.html
Please do not use this release candidate with any production work.
The developers are still studying this issue (as recently as today) and may be making further changes, but not likely before 3.0.1 is released. See here: https://bugzilla.audacityteam.org/show_bug.cgi?id=2734
Thank you for your input.
Manjel
Post by Manjel » Sun Apr 11, 2021 9:49 am
Thanks for the heads up! I saw the discussion about changing how files get exported. Hope the system doesn't get changed, as I made a script that relies on the old method.
waxcylinder
Post by waxcylinder » Sun Apr 11, 2021 11:51 am
The Macros processing has changed slightly - in 3.0.2 the macro-output folder goes to a location specified in Directories Preferences.
The defaults are
a) ...\Documents\Audacity on Windows
b) ...\Documents on Mac
But since you can change this in Directories prefs all you should need to do to get your existing script to work would be to change the setting for Macro output in Directories prefs to be the location where your files are to be processed from.
See this section from the alpha Manual for the upcoming 3.0.2 release:
https://alphamanual.audacityteam.org/ma ... ase#output
Peter.
billw58
Post by billw58 » Wed Apr 14, 2021 6:51 pm
See this post for a work-around to get the legacy behaviour (macro-output folder is created in the source folder) back.
viewtopic.php?f=68&t=117370&start=10#p422865
-- Bill
Manjel
Post by Manjel » Thu Apr 22, 2021 11:40 pm
-- Bill
Thank you!
