Utilization of the CPU's full potential
Feedback and Reviews for Audacity 3.x
This board is ONLY for general feedback and discussion about Audacity 3.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
T-buch
Post by T-buch » Sun Apr 04, 2021 12:59 pm
I have been noticing that no matter what I put it in process, then the program (not even after the big update) cannot utilize fully the CPU's full potential. 30% utilization is the best when it's really hot
why not? It could be good - cause sometimes you waiting Quite a while before some task is ending
Re: Utilization of the CPU's full potential
Post by kozikowski » Sun Apr 04, 2021 3:05 pm
I think it's still true that Audacity can only use one CPU, however, that may not be the first bottleneck. Audacity has to perform some filters, effects, and corrections entirely in memory. If you tend toward messy digital hygiene and leave apps napping in the background, or worse actually leave active apps running, Audacity may have to swap work out to the hard drive and that can seriously put a hitch in your speed.
Even worser if you have a spinning metal hard drive instead of an SSD. A guy at work and I had nearly the same laptop except I had the SSD and he had the spinning metal. I had to do a job on his machine and I thought it was broken. "No," he said. "That's normal response."
T-buch
Post by T-buch » Sun Apr 04, 2021 3:30 pm
Fresh OS install, SSD, 16 GB 3600MHz, i7-7700k - The program is only using 20% Cpu-power (peaking). It loads the memory even less. But on the SSD side, there might be a bottleneck - Its hard to say
The SSD is an old Samsung EVO 860 SATA
