Having used Audacity on WIndows 10 for a good few years with no issues, I have found that since upgrading to version 3.0.0 recordings now have glitches.
I followed the steps outlined in the FAQ section to help fix an issue like this but I have heard no improvement.
Has anyone else experienced this issue and come up with a solution.
To begin, by glitch I mean an audible brief error in playback very like an error you might hear on a slightly damaged CD but not naturally not repeating as it might on a CD. The glitch appears at random maybe three times in one min of playback.
The interesting thing is if I play the same piece of audio again the “glitchs” appears at different points in the playback and if I save a audio file as mp3 or Wav, there is no glitch. So the issues is a playback only one.
I am guessing the issue is either being caused by another piece of software or is a buffer type issue caused by a wrong setting in Audacity on my pc.
My PC is Windows 10 16GB Ram i5 Processor 64-bit processor.
Before upgrading to Audacity V3 I had tried using Stereo Tools plug in version with Audacity 2.6? The results were disastrous with the sound breaking up completely. I removed Stereo Tools prior to the upgrade but when it glitch issues happened I discovered Stereo Tools was still listed in Effects. I have since done a complete removal of Stereo Tools and restart which leaves me with my current situation.
Perhaps a reset of Audacity to default setting is the solution?
That’s possible.
To do a full reset,
1.Exit (close) Audacity
2. Find the hidden folder: *C:\Users<username>\AppData\Roaming\audacity* (where “” is your user name)
3. Delete (or move, or rename) that folder.
When you next start Audacity you should see the “Welcome” screen.
