Limiter crashes
Feedback and Reviews for Audacity 3.x
This board is ONLY for general feedback and discussion about Audacity 3.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Drexel
Limiter crashes
Post by Drexel » Mon Mar 22, 2021 10:14 pm
Hello,
when I run the limiter on tracks > 1 hour it crashes at aproximately 2/3 progress. Reproducable on 2 files.
This didn't hapen on 2.X. I am aware that the noise gate has RAM limitations on long tracks, is the same now true for the limiter? When I use the limiter on both halfs of track seperately it works fine.
Regards
Matthias
Re: Limiter crashes
Post by steve » Mon Mar 22, 2021 10:51 pm
It is right now, but it shouldn't be (it's a bug). In fact the same problem currently affects most Nyquist effects.
The developers are looking into it and hope to have it fixed for Audacity 3.0.1.
Drexel
Re: Limiter crashes
Post by Drexel » Tue Mar 23, 2021 9:55 am
Thank you again for quick clarification. :)
Re: Limiter crashes
Post by steve » Tue Mar 23, 2021 10:03 am
As you have probably worked out for yourself, the workaround until the bug is fixed, is to process long tracks in smaller sections.
batsonjay
Re: Limiter crashes
Post by batsonjay » Tue Mar 23, 2021 6:06 pm
FYI, I confirm I'm seeing the limiter crash, too. Screen recording here: https://www.dropbox.com/s/94tecxj8qbb0l ... h.mov?dl=0
As background, what's my use case for "long" limiting? I'm a DJ, and record a single, long set (in Traktor). I have historically edited the resulting recording with the following workflow:
- Select all track
- Apply limiter (set to roughly a mid-point between lowest volume track and loudest) (broken in 3.0.0)
- Select all track
- Apply compressor with makeup gain. (Sometimes simply amplify instead, but compressor seems to sound better afterwards.)
