Tool selection
Feedback and Reviews for Audacity 3.x
This board is ONLY for general feedback and discussion about Audacity 3.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
jathalls
Tool selection
Post by jathalls » Sun Mar 21, 2021 2:55 pm
In previous versions of Audacity, and certainly in 2.4.2, tool selection was sticky from one session to another. An important consideration for my own program which can fire up a copy of Audacity, opening a file and navigating and zooming to a particular location in part my spoofig keystrokes.
In version 3.0.0 the initial tool is always the selection tool, regardless of previous usage, which means that I always have an extra operation to do whenever I open a new file. Not the end of the world, but inconvenient none the less.
Re: Tool selection
Post by steve » Sun Mar 21, 2021 3:55 pm
On the other hand your program will now be more reliable in that Audacity 3.0.0 opens in a consistent state, so your program will not fail if you quit Audacity with the "wrong" tool selected the last time you used it.
Also, the previous behaviour was inconsistent in that "remembering" the last tool only applied to some tools and not others. The behaviour is now consistent.
waxcylinder
Re: Tool selection
Post by waxcylinder » Sun Mar 21, 2021 4:59 pm
Also it enables users stuck in the bear-trap of wrong tool able to exit Audacity and restart.
jathalls
Re: Tool selection
Post by jathalls » Wed Mar 24, 2021 10:54 am
OK, I can modify my routines, but when using Audacity manually I now 'know' that I have the wrong tool selected and have to explicitly change it, which is very very annoying when trying to review large numbers of files. Pardon me but I find this improvement somewhat tedious.
waxcylinder
Re: Tool selection
Post by waxcylinder » Wed Mar 24, 2021 11:31 am
Sorry, but we are not going to revert this - we had long QA/dev discussions about this and decided that the way we have it now is best for the vast majority of our users.
The best thing for you is to learn which shortcut key selects the tool you want and then press that after Audacity launches.
jathalls
Re: Tool selection
Post by jathalls » Wed Mar 24, 2021 1:09 pm
OK, OK. Interestingly though the config file still saves the 'MultiToolActive' flag when Audacity closes, promptly overwriting it again when it re-opens.
mafg1953
Re: Tool selection
Post by mafg1953 » Thu Mar 25, 2021 12:47 pm
That makes sense - but maybe in ver 3.0.1 there could be the option to create a "Startup" Macro that executes automatically when you run Audacity. That way each user could set defaults within the Macro that they prefer to be active at startup.
Mike
waxcylinder
Re: Tool selection
Post by waxcylinder » Thu Mar 25, 2021 1:08 pm
It would also enable user to set the default tool they want to work with,
Peter.
