Noise Gate doesn't work at all
Feedback and Reviews for Audacity 3.x
This board is ONLY for general feedback and discussion about Audacity 3.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Drexel
Post by Drexel » Fri Mar 19, 2021 10:06 am
Hey,
thank you for your great work, I installed Audacity 3.0.0 today, but I have issues with the noise gate:
At first, it shows me 2 Noisegates, the file with the capital letter doesn't exist, but it works anyway:
On hitting the OK button here, nothing happens:
If I can provide any more information, please let me know!
Greetings
Matthias
Re: Noise Gate doesn't work at all
Post by steve » Fri Mar 19, 2021 10:15 am
This bug has just come to light.
There's an explanation and a temporary fix here: viewtopic.php?f=70&t=116654
In addition to the fix in that post, you should ensure that you disable all versions of Noise Gate in the Plug-in manager other than the fixed "Noise Gate 2" (noisegate2.ny)
Drexel
Post by Drexel » Fri Mar 19, 2021 10:45 am
Thank you for your quick response! I will check out the workaround.
Drexel
Post by Drexel » Tue Apr 27, 2021 7:37 am
Thank you for the new and bugfixed noise gate, it is a dream to me. ;) No restriction on length (ok 13 hours....), better control on decay and it's faster than before. Thank you so much!
waxcylinder
Post by waxcylinder » Tue Apr 27, 2021 9:07 am
Thanks for reporting back Drexel (Matthias) :)
Peter.
Post by steve » Tue Apr 27, 2021 10:28 am
The fix is in the Audacity 3.0.2 version.
