Merci de noter que la plupart des membres de l'assistance d'Audacity ne parlent qu'anglais. Par conséquent, nous ne pouvons garantir une réponse aux questions en français.
Bertrand Treuil
Post
by Bertrand Treuil » Thu Mar 15, 2012 3:08 pm
If you move all those little .au files back into the Christian Leclerc_data folder it should work (unless you have deleted or moved any of the .au files.
As you said I have moved the .au files back into the Christian Leclerc_data folder with out any deleting or moving of uses .au files. BUT, if I try next to open my .aup file, the answer is
Do I have to chose after one of these two solutions Treat missing audio as silence... or Replace missing audio... ?
Bertrand Treuil
Post
by Bertrand Treuil » Thu Mar 15, 2012 3:14 pm
If I try to open one of these .au, choosing to open with Audacity, the message I get is
Bertrand Treuil
Post
by Bertrand Treuil » Thu Mar 15, 2012 3:17 pm
YEEEEEESSSSSSS !!!!!!!!!! Thank you so much ! I put the .au into the data folder and all is Ok !!!!
waxcylinder
Post
by waxcylinder » Thu Mar 15, 2012 3:28 pm
Phew.... well done, bravo
glad you got it sorted.
waxcylinder
Post
by waxcylinder » Thu Mar 15, 2012 3:30 pm
What I would do for safety is to export a WAV copy of the whole project BEFORE you do any editing.
In future immediately after capture of an unrepeatable recording session save a similar safety copy as a WAV file.
