alternate clips in different tracks
I have two tracks, with hundreds of clips in each one. I want to create an unic track with the audios alternates (first track is my speech, second track is other person speech, and I want to make a dialogue). Here is an exemple only with three clips in each track:
Any macro or help to avoid hours of manual work?
You could try this Nyquist plug-in.
I’ve not tested with thousands of clips but it works for me with Audacity 3.1.2 with a dozen clips in each track.
I’d suggest that you test it on a smaller project first.
Note that there is no progress bar - Audacity will probably flicker while it is working.
Installation instructions for Nyquist plug-ins can be found here: https://manual.audacityteam.org/man/customization.html#plug-ins
InterleaveCips.ny (3.54 KB)
It works!! thanks a lot !!!
Super :slight_smile:
Out of interest, how many clips did you process with this plug-in, and how long did it take to process on your (Windows) machine?
I Have tried 100 clips of eeach track (200 clips in total). it does it in less than a minute.
