Resample-Macro
Questions, discussion and recipes for scripting and batch processing in Audacity.
See also the "Scripting" section of the Audacity manual.
mafg1953
Resample-Macro
Post by mafg1953 » Sun Mar 07, 2021 5:56 pm
Hi,
I can't seem to find where it might be possible to resample an audio file within a project using a macro. Is it possible to do this?
Thanks,
Mike
Re: Resample-Macro
Post by steve » Sun Mar 07, 2021 6:23 pm
Do you mean that you want to change the sample rate of an audio file?
If so, then use the "SetProject:" command to change the "Project Rate" prior to exporting.
mafg1953
Re: Resample-Macro
Post by mafg1953 » Sun Mar 07, 2021 6:35 pm
Thanks Steve,
I do already change that when I export a completed file.
My projects usually come to me at 32kHz and since I will be exporting them at 41kHz, I normally use the Tracks > Resample command as soon as I load the original file so that I work with them at 41kHz. Maybe I don't even need to do that but that is what the group suggested to do when I started editing for them. Is there any reason that I need to keep resampling when I get the original file or is it sufficient to work with the file at 32kHz and just do the resampling at the time of export?
Thanks,
Mike
Re: Resample-Macro
Post by steve » Sun Mar 07, 2021 6:55 pm
If you are working with multiple files in the same project (at the same time), then it can be more convenient to convert them to the same sample rate (some effects will complain if you try to apply to multiple tracks at the same time that have different sample rates.
If you are working with just one file at a time, then there's probably no advantage to resampling - just set the Project Rate and let Audacity resample on export.
