SilenceFinder cancels macro execution?
Questions, discussion and recipes for scripting and batch processing in Audacity.
See also the "Scripting" section of the Audacity manual.
codebycandle
Post by codebycandle » Mon Feb 08, 2021 5:46 am
Dear Scripting Ninjas,
Recently created a macro to handle batch processing.
Works great! -unless, it comes across a file that has "no silence' to process (as it halts subsequent execution).
Does this mean I need to create a "Nyquist Macro" script to handle "null' cases?
(-to allow handling groups of files that MAY / MAY NOT have silences to trim.)
Fwiw, tried this route, but have been having trouble getting (AUD-DO "SilenceFinder") command working?
Might any kind soul have a link to a demo script using "SilenceFinder"?
(Found "InsertSilence.ny' on the forum, but looks to be v3?)
-your assistance / wisdom is humbly requested!
Re: SilenceFinder cancels macro execution?
Post by steve » Mon Feb 08, 2021 10:33 am
Is that because it is waiting for you to dismiss the "no Silences Found" message?
If you (manually) dismiss the "No Silences Found" message, does the macro continue and complete successfully or are there additional problems?
jademan
Forum Crew
Post by jademan » Mon Feb 08, 2021 11:11 pm
So I've been playing with macros a tad and I was thinking that adding a little bit of silence to every file might "fix" the problem.
The following macro should add 1 second of silence before and after the track if you have at least one second of audio to begin with:
Code: Select all
SelectAll:
Duplicate:
Select:End="999999" Mode="Set" Start="1" Track="0"
Cut:
Select:End="1" Mode="Set" Start="0" Track="0"
Silence:Use_Preset="<Current Settings>"
Select:End="999999" Mode="Set" Start="0" Track="1"
Copy:
Select:End="1" Mode="Set" Start="1" Track="0"
Paste:
Copy:
CursTrackEnd:
Paste:
SelectAll:
SelectTracks:Mode="Set" Track="1" TrackCount="1"
SelectAll:
MixAndRender:
I am sure steve knows a much easier way to do this. :)
I hope this helps. :D
