using mod script pipeline on ubuntu
martinbarker99
hello, ive used mod script pipe on windows before and it was very easy to enable (just check mod-script-pipe to enabled in the options menu and restart), i'm trying to set this up on my ubuntu laptop now but am not sure how to do it. things I read online say I need to build audacity with mod-script-pipe enabled? Do i need to download the audacity source-code from github, add mod-script-pipe, and install it that way?
Need some help please, thank you
Re: using mod script pipeline on ubuntu
Which version of Ubuntu do you have?
On a scale of "total novice" to "total geek", how would you rate your abilities with computers?
martinbarker99
oh yeah i should have included my version my bad; Ubuntu 20.04 LTS
id say im pretty experienced, if i can get directed to instructions on how to set up mod-script-pipe in ubuntu audacity i could probably figure it out. from my google searching on the topic though i dont get any official documentation on steps / commands to run, just forum posts like this.
im thinking i need to download the audacity source-code, build it with mod-script-pipe, and install this custom mod-sciprt-pipe enabled version on my ubuntu computer?
Just seems like so much more work for something that is checking a box on windows
martinbarker99
okay so there was a very obvious documentation page i've been following:
https://wiki.audacityteam.org/wiki/Building_On_Linux
I got the wxwWidgets/ folder, and I have cmake version 3.16.3 on my ubuntu command line.
but im stuck on this step:
I am running this command in the audacity git repo I cloned, inside the build-cmake folder I made, so my filepath is:
But running this command produces the err:
Going to try and trouble shoot this some more, thanks
Code: Select all
. Generate the makefiles
cmake -DCMAKE_BUILD_TYPE=Release ..
Code: Select all
~/Documents/project/wxWidgets/wxWidgets/buildgtx/audacity/build-cmake$ cmake -DCMAKE_BUILD_TYPE=Release ..
Code: Select all
-- Check size of size_t - done
-- Check size of wchar_t
-- Check size of wchar_t - done
-- Check size of void*
-- Check size of void* - done
-- Building for 64-bit target
-- Found Python3: /usr/bin/python3.8 (found version "3.8.2") found components: Interpreter
-- ========== Configuring wxwidgets ==========
CMake Error at /usr/share/cmake-3.16/Modules/FindPackageHandleStandardArgs.cmake:146 (message):
Could NOT find wxWidgets (missing: wxWidgets_LIBRARIES
wxWidgets_INCLUDE_DIRS)
Call Stack (most recent call first):
/usr/share/cmake-3.16/Modules/FindPackageHandleStandardArgs.cmake:393 (_FPHSA_FAILURE_MESSAGE)
cmake-proxies/cmake-modules/FindwxWidgets.cmake:1018 (find_package_handle_standard_args)
cmake-proxies/wxWidgets/CMakeLists.txt:21 (find_package)
-- Configuring incomplete, errors occurred!
See also "/home/martin/Documents/project/wxWidgets/wxWidgets/buildgtx/audacity/build-cmake/CMakeFiles/CMakeOutput.log".
See also "/home/martin/Documents/project/wxWidgets/wxWidgets/buildgtx/audacity/build-cmake/CMakeFiles/CMakeError.log".
I'd suggest that you start over and follow these instructions: viewtopic.php?f=19&t=111755
martinbarker99
thx i will try that. I recently tried again following a seemingly different set of isntructions on the wiki, got a little further and was able to build audacity, but couldnt launch it. https://stackoverflow.com/questions/626 ... -launch-it
I've posted a reply.
martinbarker99
thx I went over those instructions and got my build audacity to launch, when I launch it with the command "./audacity" like in the instructions it will open the audacity program. I can see the mod-script-pipe option in preferences and i set it to enabled. restarted audacity (checked that the mod-script-pipe is still enabled, then I download pipe_test.py from githube [ https://github.com/audacity/audacity/bl ... pe_test.py ] download the file in my documents folder, and run it with sudo, but I get the error:
There is another thing I need to do in order to use mod-script-pipe in ubuntu aside from the instructions here right? : [ viewtopic.php?f=19&t=111755 ] I think I need to download a mod-script-pipe file, add it to my audacity build folder, then re-run the build steps, any advice on where to find goof instructions on this
Code: Select all
$ python3 pipe_test.py
pipe-test.py, running on linux or mac
Write to "/tmp/audacity_script_pipe.to.1000"
..does not exist. Ensure Audacity is running with mod-script-pipe.
Don't use sudo.
Sudo should only be used when you need to modify the system (such as installing or updating), otherwise run everything with your normal user credentials.
