Mac HighSierra export command default location in applications folder
Questions, discussion and recipes for scripting and batch processing in Audacity.
See also the "Scripting" section of the Audacity manual.
martinbarker99
Post by martinbarker99 » Mon Feb 10, 2020 8:26 am
Hello, I have mod-script-pipe working on mac HighSierra 10.13. If I use the pipeclient.py file to test the command:
Export2: Mode=Selection Filename="sampleFile.mp3" NumChannels=2
It will render the sampleFile.mp3 starting at the 'Applications' directory. So the output filepath is 'Applications/sampleFile.mp3'
My question is how can I change the output filepath to be elsewhere, like my /Users/martin/Documents folder?
On windows I can specify the full filepath from the start of the c drive for the filename, is there some way I can do that on mac OS to use the absolute path of the mp3 file in the export command? I want to do something like:
Export2: Mode=Selection Filename="/Users/martin/Downloads/tempFolder/sampleFile.mp3" NumChannels=2
It causes an error saying FileNotFoundError ERRno 2 No Such file or directory
Re: Mac HighSierra export command default location in applications folder
Post by steve » Mon Feb 10, 2020 10:24 am
You need to enter the full path and file name to the Export2 command.
For example (this example is on Linux):
Code: Select all
Export2:Filename="/home/steve/Desktop/exported.wav"
Note that the file path must be a complete file path, and the folder must exist.
Check that the folder "/Users/martin/Downloads/tempFolder/" exists before you export.
Post by kozikowski » Mon Feb 10, 2020 4:06 pm
And use good filename hygiene with no punctuation marks other than -dash- and _underscore_.
